mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Sat Feb 02, 2008 4:27 pm
Ahhhh, I see. Actually, you can put any 4/87+ VG30E in your car though you do want to avoid the VG30E that is available in the Nissan, Ford, and Mercury vans (cams different to make a non-interference design so lower power output is the result). All you have to do is swap all of the external parts from the stock VG to the replacement VG and it'll bolt right in. Motor mounts, sensors, intake and exhaust manifolds, accessory brackets, etc.
As far as putting the DE in, the only major issue I could see is your accessories (power steering, a/c, and alternator). The brackets may give you some trouble as far as trying to use the Z31 parts on the DE, you may have to use the Z32 accessories to make it work... that's one of the things I'm not sure about.
