VG30DE-VG30DET
Discuss topics related to the VG and VE series engines.
naladude911
Car: 2001 Infiniti QX4
Is there anyway to put a single turbo on the N/A VG30DE? Because the Nissan Cedric came with the VG30DET
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
You most definitely could, but to keep it safe you really need to build the NA to handle boost. Its high compression ratio makes it essentially "weak" when it comes to boost so you really need to put in some lower compression pistons to get the engine to handle it. On top of that you also need to upgrade the fuel system and tune the ECU accordingly.
Its a bit of work but would most definitely be worth it... boosted engines are by far the most fun, in my opinion.
naladude911
how do i get the pistons and turbo manifold? I can get the JWT ECU
mtcookson
1992 Iinfiniti Q45
and much much more
For pistons you could go with stock TT pistons or you could get some aftermarket pistons. For the manifold, that one is a bit more difficult. You may keep an eye out on eBay to see anyone happens to have any listed or you could also go with a custom manifold setup.
naladude911
word. When i get some $$ cant i just get the JDM VG30DET manifold? And maybe a SMIC or a FMIC?
mtcookson
1992 Iinfiniti Q45
and much much more
You just need to make sure it'll fit in the J30. I'd say that should work fine since the Japanese version of the J30, the Leopard, was equipped with a VG30DET in an upper model.
naladude911
no, it was the VH45DE from the Q45. KBfliip is busy swaping it out right now in his J30.
mtcookson
1992 Iinfiniti Q45
and much much more
Thaaaat's right, it was the earlier Leopard with the VG30DET. The later Y32, J30 equivalent had the VG30DE and the VH41DE, not the VH45, from what I've been able to find.
naladude911
o really? So the F31 right? The M30 in USA?
mtcookson
1992 Iinfiniti Q45
and much much more
Yup, that would be correct. The F31 Leopard's were equipped with:VG20E - early and late models ("zenki" and "kouki" respectively)VG20ET - earlyVG20DET - lateVG30DE - early and lateVG30DET - late
The US M30 "only" got the VG30E with a 4-speed automatic transmission. I actually prefer the VG30E really as they're a bit lighter, a little more compact, and just as strong when it comes to boost.
naladude911
ya. idk if it will be a direct swap though. i posted this in the j30 forums to
Return to “VG30 / VE30 Forum”
