vg30de under boost?
A home for 1983–1989 300ZX owners!
KrAzy24DE
Car: I need money
Would It be posible to change over a n/a motor wiriing harness and comp to a tt harness with the tt coil packs and all other nesc. stuff to have the motor turbo'd (I know the comps High on the n/a but was Just wondering).....Ive seen the hks kits where they say you can use it on the n/as But I was wondering if it was posible
boileralum00
Car: 94 Miata, 95 FZR600R
It has been done on a few cars by shops such as Z1Motorsports and SGP. I would recommend lowering your compression (be either installing a TT block or installing aftermarket pistons) if you want any useful life out of your motor. Also, you would still need all of the associated piping for the turbo system. The coilpacks are the same for the TT and NA, and the wiring harness *could* be re-used if you install an aftermarket boost controller, but since the motor is going to be out to install the turbos anyway, you may as well install a new harness. Other things you will need are an ECU and bigger injectors. There is a good writeup that is stickied at the top of the Technical Forum on twinturbo.net regarding NA to TT conversions, I highly recommend reading it if you are considering going that route.
KrAzy24DE
Car: I need money
thanks alot bro
can I ask 1 more question Whats the Diffremce between the 91-5 coil packs and the 96sthx
boileralum00
The coil packs are all the same, to my knowledge. The injectors changed in 94 or 95, and therefore the EFI harness is different too, since the connectors are different.
Return to “300ZX (Z31) Forum”
