nissandoms47 »
https://forums.nicoclub.com/nissandoms47-u53256.html
Mon Jul 14, 2008 4:07 am
You'll need to swap the harness out of the doner car. Since its dohc you'll have some different sensors. Depending on what transmission you have.. (manual will be easier cause you dont have a tcm to worry about) But nissans are pretty forgiving when it comes to engine harnesses. You can just swap the whole harness and ecu, then you'll have to wire the new harness into your body harness. (fuel pump, gauges, ac compressor switch, etc..) Its not really that wide of an engine. Tylers VH is wider then that.
