Vg30de cylinder head help
henroc28
Car: 1992 300zx n/a
Bought a Motor that had a broken camshaft.it was broken at the cam gear clean off. Tried using another cam from another motor when I tried to tighten it down to spec it wouldn't turn by hand. There Is zero play. Can someone tell me the cheapest route to fix this problem. Is it just buy another head with cams or take it to a machine shop. Any and all input is appreciated. I'm a first timer to any Nissan builds.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
You can't just slap a new cam in without checking clearances. Take your head to a machine shop.
NolimitZ32
Cam bores are done individually for each cam. As Ace aid, its not as easy as just swapping in a new cam.
henroc28
Car: 1992 300zx n/a
Thanks ace..I'm still learning gents..soaking up everything.
Ace2cool
Yeah it's a lot to learn. We just know cause we've been there already, haha.
henroc28
Car: 1992 300zx n/a
Lol That's why I joined ace, thanks again..
akwdcaveman
Car: 1990 300zx
Can you explain why you cant? Im also pretty new to doing internal work. I figured if you got a cam from a different engine of the same model the cams would be the same?
NolimitZ32
Because every head is line bored slightly differently, in reality it depends on the tolerances of your engine, some cars/engines/manufacturers you can do it, on others you cant
akwdcaveman
Car: 1990 300zx
Good to know thanks!
