mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Fri Jun 13, 2008 5:22 am
The turbo manifold will definitely bolt to the engine, you'll just need to make sure you have the proper clearance. There is a crossover pipe that goes behind the engine, you'll need to make sure you have clearance between the engine and firewall for that. Also, you need to check for any possible clearance issues with the steering rack and/or motor mount where the turbo will sit.
