VG30 Piston information
Discuss topics related to the VG and VE series engines.
killerwatt
I am looking at using some VG30DETT pistons in another engine & I am wanting to check the specifications.
Can anyone tell me the following for the VG30:Bore Diameter: ???Pin Diameter: ???Compression Height: ???
I would also like to know if these pistons are forged or how much boost they can handle?
Thanks, Killerwatt.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
91.186mm bore diamiter accoring to MSN carpoint.
killerwatt
Thanks for the info... but That doesn't sound right to me... can you trust MSN carpoint???
What about pin diam & height?Anyone know these details?
eh?
For 1996 z32:Depends on the grade, and either tt or naBore ~87mmpin diam ~22mm
Comp height you're on your own.
killerwatt
Thanks for that eh?
That is exactly what I am looking for..
So do you reckon that the tt engines use forged pistons, where as the na engines don't?
I would definitely be looking at the forged pistions, as I am looking to use these in a high boost environment.
Return to “VG30 / VE30 Forum”
