So the original poster couldn't put a VG30DE out of a 1994 300zx into a '89-'94 Q45?Q45tech wrote:The Clean Air Act prohibits installing an OLDER year engine into a street vehicle, even if the displacement is smaller. Also the engine must have been available in that model year for sale in US.
If you can't drive it on the street WHY?
Not per the "letter of the law" of the Clean Air Act.anlasak wrote:So the original poster couldn't put a VG30DE out of a 1994 300zx into a '89-'94 Q45?
Pretty brave statement for someone in LA.rps13dn wrote:I can care less about the Clean Air Act. if that was the case i wouldnt ask about the swapthe q is going to be fully gutted sitting on 16x8 A.R.E. meshys jic coilovers I need i small power full engine to stick into the empty engine bay i have a vg30dett sitting here so i was wondering how whould that work but since u guy say its dumb ima go a different way what would u guys suggest
SR? What's that?elwesso wrote:why not go with an ESSSS ARRRRR? Lighter and easier to mod...
Or, we could swap in a heavier motor with 2 less cylinders thats arguably more of a PITA.
regardless, the logic escapes me.
I think the VH45DE is about 500 lbs.rps13dn wrote:whats the weight on both engines
yep, and the VG30DETT with all its associated accessories and stuff weighs about 650-700lbs.Haitian_King wrote:
450 peak short term HP number on dyno and LONG TERM reliable, DURABLE real output are two different concepts.rps13dn wrote:i also have a ka24det last dyno pull out 450 what if i drop that in the q
Get the adapter plate. I know of 3 guys that have already done this.rps13dn wrote:how do u go about making the vh45de 5 speed clutch flywheel driveshaft etc.
Not to mention, the VH45 was over-engineered and overbuilt to last, whereas the VK45 is proving to be under-engineered and developing major wear problems early in life { oil burning and therefor loss of compression and power}elwesso wrote:in all reality VH45s make as much power as VK45s do with a chip. VK45s were over rated and VH45s were underrated.
