I'm considering buying a 90 300xz with 140k on the clock. I always do a compression test on a vehicle before i buy it. What are good compression numbers on the NA vg30? I know they have like 10.5:1 compression so i figure the compression numbers should be pretty hight.
So what should I be looking for in terms of compression numbers? Also, what is the max variance between cylinders that is acceptable.
