VG swap from t/b to injected
markmdz
Car: '86.5 Hardbody Reg.Cab. V6 4x4 s/b
I've got an '86 hardbody with that beloved (ie. so far I hate it) t/b injected V6 motor, and mainly due to the cost of the damn injectors (which are suspect to be leaking right now) I'm curious to see if anyone has kept the motor in the truck and just swapped out the throttle body and whole intake sys for the newer, more common, more powerfull injected version.
Either this, or is there a carb swap for the t/b? If there is, I'm all for going 'old school' and dumping in a full carb setup. (As though that's not evident by my '89 Honda Accord w/ dual weber DCOE's.)
Anyway, I'm sorry if this has been covered already, but a search proved not-so-helpfull this time around.
If anyone's got any info, and is willing to share, I'm willing to listen.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
You could probably take the wiring harness, ECU, intake, injectors, and the entire multi-port setup from a later VG and adapt it to your motor, since the bottom ends are the same.
It'll definitely be a job. Happy junk yard hunting!
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
Swap an engine assy.The VG30I has no provisions for the knock sensor.
markmdz
NM50 wrote:Swap an engine assy.The VG30I has no provisions for the knock sensor.
Sorry to sound ignorant, but I'm lost on that one. Are you suggesting I swap out the entire motor? I would assume the whole harness would end up going with that as well right?
nismopu
Car: 1987 Nissan 300ZX
1997 Nissan Maxima
1976 Datsun 280Z Turbo
the knock sensor is pointless, and could be placed anywhere on the engine if you wanted to run one. I suggest getting the efi setup from a HB or pathy and plugging it into your truck harness. Its a pretty straight forward deal but just time consuming. What exactly are the symptoms of your truck running poorly? peace.
markmdz
First, thanks for your help w/ this.
Second,
Here's a link to a thread I started, where I have only begun to describe the troubles w/ the truck running poorly.
zerothread?id=328662
