I have a 86 vg30et with the harness, ECU, and accesories that came in the 300zx installed into a 97 nissan HB. I left the stock KA ECU in place to act as a control module for the dash and a few other things. The 300zx ecu runs ONLY the engine but, since its been wired in I cant get the injectors to click. I know the CAS is good, injecotrs have power, all other sensors have power, and I have tried other injectors but to no avail. I know the CAS is working because the coil ignites when we spin the dizzy but you cant hear the injectors clicking at all. We have double checked and triple checked our wiring but we cant come up with a logical reason why theyre not functioning.
With a voltmeter hooked up to the signal side we can see a varying in voltage as we spin the dizzy but stabalizes when we stop spinning it. Does that mean the ECU isnt sending enough voltage to the injectors? I am also wondering if theres some sort of resistor pack that I am not aware of? I appreciate any help you can provide. peace.
