edit: guess i could add the pic
i'll see what I can do tonight. I'm not sure if we saved any logs from the "final" tune, but I know we have one from one of my lean tuneseh? wrote:Post the complete log. I think it's just hunting for idle rpm and overshooting/undershooting.
That is exactly what seems to be happening. If you look, the MAF and RPM respond in the same manner on the graph as the throttle is closed. I think the IACV needs to be tuned in the ecu, or the throttle plate stopper is set all the way to closed making the IACV load cycle too much to handle. Usually the stopper screw should be set where the engine can still idle 450-500rpm without the IACV's help. The IACV could also be tuned somewhere in the PFC. It could also be through there, that the PFC is telling the IACV to open up too much at a time, bogging out the engine from a quick lean, then add fuel right after to compensate before it stalls. Adding this fuel would suddenly cause all this lean air to richen and burn causing the rpm to shoot up, then over react and close the air off and the rpm drops again. Rinse and repeat = possible hunting problem.eh? wrote:Post the complete log. I think it's just hunting for idle rpm and overshooting/undershooting.
yea, it does have a slight hunting problem for sure...we fixed it by turning the injectors on earlier after we let off of the throttle. I'll see if i can get an actual log to load up, and will let him know what we have been talking about. The IACV problem sounds like it could be it for sure.ItzGenX wrote:That is exactly what seems to be happening. If you look, the MAF and RPM respond in the same manner on the graph as the throttle is closed. I think the IACV needs to be tuned in the ecu, or the throttle plate stopper is set all the way to closed making the IACV load cycle too much to handle. Usually the stopper screw should be set where the engine can still idle 450-500rpm without the IACV's help. The IACV could also be tuned somewhere in the PFC. It could also be through there, that the PFC is telling the IACV to open up too much at a time, bogging out the engine from a quick lean, then add fuel right after to compensate before it stalls. Adding this fuel would suddenly cause all this lean air to richen and burn causing the rpm to shoot up, then over react and close the air off and the rpm drops again. Rinse and repeat = possible hunting problem.
Edit: I also noticed on the RPM that after you let off, the RPM drops down to 450-500 before it comes back up, then begins it's hunting problem. I think you should solve this hunting idle before trying to adjust the fuel around too much. When I first did my idle tune on my Haltech, I had a hunting issue with 'rich' numbers too (11-12:1). Really, it just needed 'more' fuel and a steady idle map. After it held steady at idle, the AFR's were reading 15.5:1 even though I added fuel.
