very upsetting
dr.drew
Car: 89 240 sx
I have a 89 240 sx runs great BUT how do you get around the 4500 rpm in 5th gear.....
is the limiter in the computer, ingnition, coil,what can i do. i need that 2000 rpm
dfw240_EE
Car: 1992 240SX
I thought the limiter was only present in the automatics?
dr.drew
Car: 89 240 sx
you got me i have no idea it pisses me off 4th gear will pull to 6700 shift to 5th 1 second later at 4500 rpm every thing shuts down
black s13
only manuals have it. its used to limit the speed, and is taken care of by the ECU.
swap to an auto ecu, or but the greddy (?) fuel cut defender.
dr.drew
Car: 89 240 sx
auto ecu and man ecu will interchange
dr.drew
Car: 89 240 sx
the reason i ask these stupid questions
i have been in to mopars i have a 70 challenger R/T 383 4 speedand a 76 D100 pu with a 440 auto
i just bought a car to go back and fourth to work had no idea what i bought the you guys came out of the wood work telling me about my car i love that 240 it is one of my favorites. so far i have put k/n cold air,obx stainless header,3" exhaust, msd, taylor 409 10mm wires nothing special just don't know to much about imports..
thanks for any help
RBpoweredSileighty
dr.drew wrote:the reason i ask these stupid questions
nothing you ask is stupid. if your not sure then you did the right thing by asking.
dr.drew
Car: 89 240 sx
oh yeah front and rear strut tower bars besides No2 and turbo what other bolt on's can i add to the car that will actually improve the performance
andrave
Car: 1989 Nissan 240SX Coupe
cams make a big difference.
as for the speed cut you can do a search on that, there is a way to cut some wires (or more practically) to wire them to a switch that will defeat the speed cut. I don't remember off hand which ones but I know this has been covered a lot. The auto ecu should also work too and since they are so cheap used that might be the way to go.
bcar240
Car: 1993 240SX HB
if you find a write up on how to disable the speed limiter, make sure it is for your engine. The 240 started out with a KA24E and got a different engine in 1991, the KA24DE. The "cut one wire at ECU" method is only for the KA24DE. If you try this with an E engine, it will screw things up from what I hear.
andrave
not true, you can do the same thing to the ka24E, you just have to know the right wires to snip.
SeVa-S13
Car: '05 GTO 6spd
You really need to go 120+ mph in your 16 year old car with stock suspension? Just wondering why you "need that 2000 rpm"...
dr.drew
Car: 89 240 sx
other than the mickey mouse performance items i have installed i have also installed, tie rod ends, new rack and pinion, ball joints, cross drilled and slotted roters, they sucked and warped very quickly. so i went back to stock roters, new calipers, front and rear sway bars. so the suspension is very tight and responsive.
I REALY WANT THAT EXTRA 2000 RPM
dr.drew
Car: 89 240 sx
MAIN REASON CIVIC'S
I HATE CIVIC'S I CAN SLAUGHTER THEM OFF THE LINE THROUGH ALL THE GEARS HIT 5TH AND SLOW DOWN THEY PASS ME
ARGGGG MAKES ME MAD
robbbby
How fast are you going in fifth gear when it cuts out at 4500 rpm? Are you sure it is a rev limiter and not the governor?
dr.drew
Car: 89 240 sx
no the rev limiter is at 6800 the gov is at 4500 in 5th it definitly a gov
dr.drew
Car: 89 240 sx
actually i have no idea if you have a 240 sx with digital read or hud out you know what i mean when i say i have no idea
have to buy a new hud to know how fast
bcar240
Car: 1993 240SX HB
andrave wrote:not true, you can do the same thing to the ka24E, you just have to know the right wires to snip.
ya, but since it is different wires, I was just saying if he found a write up or something, make sure it is not for a DE.
dr.drew
Car: 89 240 sx
where would i research that info i have read auto books on 240's even read and looked in tuner mag's have not come across anything about how to disconnect the limiter
bcar240
Car: 1993 240SX HB
easiest way I have heard is to get an ECU from an auto of the same engine. If you can find a junked 89-90 240 that is auto you could get the ECU and swap it out for yours. Shouldn't take very much time at all really. Just unmounting the ECU, unplugging it, and adding the new one.
frapjap
'07 Subaru Legacy
and b car has THE simplest solution. It costs about 50 bucks...most likely less on Ebay sincenot very many people choose to biuld the E motor.
dr.drew
Car: 89 240 sx
what is an E motor
is it a ka24E
dr.drew
Car: 89 240 sx
when i put the new motor in my friends tried to get me to put in a sr20det but the computer and wire harness cost more than the motor
i bought my motor at greenleaf.com complete motor with all sensors under 25000 miles ready to drop in and run for 500.00 w/ 6 month warranty i think they get them from japan
bcar240
Car: 1993 240SX HB
ya the E motor is the KA24E. They probably didn't get it from japan, there are so many junked KAs here they could pick from. The SR wiring should cost about $500, that is sending it to a shop to have it spliced with the KAs old harness.
frapjap
'07 Subaru Legacy
In a while, do an updatge about the green leaf motor. I'd like to see how it works out for you.
s13sr20chris
i cant seem to find a wiring diagram for this thing but it stands to reason that its an open or cosed switch. if you unplug the od switch on the trans it will either tell the ecm you are in 5th or not. drive and see if you have the limiter. then if you still have it, put a jumper wire in the electrical connector and see if you have it.
doainwpg
just unplug the sensor from the transmission, no more govoner. if i remember correctly there's 3 connections on your transmission from front to back it's reverse switch, 5gear switch(disconect this one) and speed sensor. if i'm wrong i'm sure someone'll correct me soon enough
89 240 SOHC
Car: 1990 Micra S13....Micra with S13 Seats and other S13 accents to follow
I thought if you unplugged the fifth gear switch the car dies when you put it into fifth gear....Haven't driven mine yet but am gonna take it out tonight and play with it....first time getting to drive it after buying it 4 months ago.I have my speed sensor unhooked from the trans (5 speed) and it was like that when I bought the car.
