SolaraOnBronze »
https://forums.nicoclub.com/solaraonbronze-u107872.html
Sun Sep 27, 2009 7:00 am
I know there a lot of threads on the subject, but bear with me...
So here is the deal- I replaced all of my turbo and exhaust gaskets last week and the car ran great after that. Here is my setup:
SR20DET BlacktopIntake, Exhaust, Front Mount, Stock Turbo, Walbro pump, etc.
The car ran and drove great after that with no issues at all. I drove to my in-law's house, which is about 90 miles, and when I got off of the freeway I noticed the car starting to shake. The exhaust note changed and started to sound like a subaru, very rough and louder than it was before. The car idled rough and was shaking, but didn't seem like it wanted to stall out or anything.
Oil pressure, oil temp, water temp, and vacuum were all good. The car could go into and hold boost just fine, but was extremely sluggish and bogging, in addition to still sounding like a subaru. Got to where we were going, shut it off, and let it for about an hour. When we came back to the car, it started right up and idled normally. The issue seemed to have gone away.
When I got it home (about a 5 minute drive from where we were) I realized when that I had only finger tightened the bolts on the air filer when I replaced the turbo gaskets (FAIL). Only one was left and it had started to back itself out. I went and got new bolts, tightened all 4 up, started the car- and everything was fine.
I drove the car for an hour to a big meet the next day and everything was great- the car pulled hard, idled right, sounded right, and felt great- no issues at all whatsoever. When I went to leave the meet, I had someone take a couple of pics for me. I let it idle for about 5 minutes, and the problem started all over again- almost like someone flicked a switch. Rough idle, subaru exhaust note, etc. I drove it home an hour with it running like crap and it never went away. I checked the air filter to see if it was loose like it had been previously, but everything was still tight and good to go.
I guess I'm just wondering what sort of things could come and go randomly like that. It seems like the car is only running on 3 cylinders if I had to guess- it take a bit to get up to speed and the car almost has to be in boost to go 75-80 on the freeway. I have not replaced the spark plugs since I have owned the car- could that cause an issue like this? My first plan of attack is to pull each plug to see if they are all getting spark.
Can anyone tell me how to check the injectors to see if I have a bad one? I check the resistance, correct? Any input or feedback is welcome, I am going to get the car back to my place today and start trying things after work tomorrow. Thanks in advance!
Damon
