Let me first off say that the kit I purchased was from a guy who no longer answers his phone or emails, so I cannot contact him....and the pictures he sent me of the kit installed on his car are all very small, low-resolution pictures. So basically, i'm installing this kit with no instructions and I'm running into some blocks...I need the *experts* help, ie, orion, c-kwik, WDRacing, DavEEE, and whoever else I forgot.
1.) Can the two lines going from the throttle body to the evaporator canister stay where they are under boost?
2.) Does anything special need to be done to the PCV system, such as the PCV valve? I already have the connection from the valve cover going to the intake side of the turbo....
3.) Do you have to leave the vacuum line connected to the stock fuel pressure regulator when using an aftermarket (bosch) one?
4.) Where does the small vacuum hose that used to connect to the stock air-intake pipe right near the TB go, and what does it do? I know it's part of emissions control and that it's not under vacuum, but I'd like to know exactly what it does so I can either forget about it or run it over to the intake side of the turbo.
5.) Open the following link of the fuel pressure regulator I received, and tell me which is the inlet and which is the outlet!(If you rotated the picture 90 degrees to the left, then the FPR would be "right side up," ie, you could read the words "Bosch"
http://24.59.111.91/pichost/pic/112-1201_IMG.JPG
Thank you very much in advance!
Marc
