jdmmba »
https://forums.nicoclub.com/jdmmba-u4110.html
Tue Apr 29, 2003 8:28 pm
For a quick and simple fix to the problem with the troublesome headunit, you could simply buy a newer unit off E-bay, then sell your broken one. The link with the instructions on how to remove your headunit tells you at the bottom that they buy gently used equipment. I have already sold my broken unit and someone else's to Bob for $75 each. Not a bad deal and it should pay for more than half the replacement. If you have a 93-94 J30, I would recommend buying a newer style headunit (less wear and longer life), then you need to buy an adapter for $20 to enable you to use the older style wiring with the newer style headunit. All in all, this shouldn't cost more than $50 more than the price you can sell the broken one for.
