VERY!!!! rough idle
killbillet
Car: 1996 nissan 240sx se
I just installed a e fan setup, I left the fan clutch on but took the blades off just for now to see how the fans go....I also took my vc off to check my chain tensioner because im getting the famous chain tick but both of my upper guides are already removed......so i didnt bother cleaning the tensioner because it was getting dark, so , i removed my vc and thats it.....now when the car is running hot for a while normal running temp, at a stop light it wants to idol so rough that it almost cuts off.......and sits there until i take off again.....im at a loss, ill look at it more tom but idk.... maf problem??? to rough for tps sensor......
UPDATED INFO: I can slow to a stop and idle is fine, its when I apply My brakes that it does it....and info on that?lolI advanced my timing as far as it will go.....fixed it a little, but it still wants to act up
Modified by killbillet at 3:27 PM 3/19/2009
lancet913
Car: 1996 240sx se
KA24DET @12psi
Does it happen all the time or just when the e-fan is on?
killbillet
it seemed like just when the fan is on, i have it wired up with the ac fan....i was thinking about straight wiring it to a switch tom to see if that is the problem
lancet913
Car: 1996 240sx se
KA24DET @12psi
I have altima e-fans on my car. When the cooling fan comes on the RPM's drop a bit but it dosn't want to cut off.
killbillet
im just going to go through everything with the firing and see whats causing it, might be a misfire at idol.......i know one thing, my annoying tick from the cam chain is extra loud and even more annoying..I just didnt have the time to fix that yesterday
handinpants
Car: 240sx fast... powered by mice on a wheel.
do you have an air idle control valve?
killbillet
my aiv.....egr and all that crap are still there, im not taking it off until the new motor goes in.....and that will be a while. Im just trying to get as much load off of this motor as I can since it has over 200xxx miles. Im going to check all my vacuum lines today.. But it seems to me to be a timing issue im just trying to get a second opinion
killbillet
I updated the info, only does it when breaks are applied....so what im thinking is the check valve, plastic pos
svfd5140
Car: 1995 240sx se
Are you losing vacume at yoour brake master cylinder.
