bvanev »
https://forums.nicoclub.com/bvanev-u8898.html
Tue Jul 22, 2003 5:10 pm
Here is my situation. rchased an s-13 sr. I struggled with the getting the motor to idle and accelerate smoothly, only to find out after two weeks of troubleshooting that the MAFS that I had been told was tested good was faulty. I replaced it with a Q20 MAFs (I am not sure if it is truly compatible, but the motor ran great). After about 20hrs of driving time, I noticed a rare exhaust backfire, (I figured that I would have time to get it home and adjust the timing). After shifting hard into 2nd gear the car sputtered black smoke and bogged down. I have spent sevearl weeks now troubleshooting everythign I can think of. I attribute part of my problem to the Blitz DD BOV as it vents metered air into the atmosphere vice recirculating it. As far as I can tell the ECU is good, MAFS good, O2 good, EGT good, no vacuum leaks, good compression, solid intake piping, good pressure regulator, fuel injectors (very misty pattern) good ignition circuit. I am about out of ideas, I ahve tried resetting the ECU, with no avail, the ECU doesn't call out any fault codes (although there are no LEDS on it as it is a factory refurbish unit).
If I let the car sit for a few days it will start and run for a few seconds then die due to the cylinders being washed down.
Any help is greatly appreciated.
