Actually, several companies already make kits for the Ford 302. SInce the oil pump is located in the front of the pan, there is almost no modification necessary short of transmission and motor mounts.The stock transmission in your S13 will not work however due to the difference in sizes of the two flywheels. You will need to get a T5, T45 or T56 transmission to use in the car.
Also, the ford motors are significantly heavier, so be forewarned that the car will not steer nearly as well, and routing powersteering is near impossible.
feel free to email me anythime at
[email protected]
*edit* I know my spelling sucks. You try crawling out from under a car to answer a post
