VERY odd problems
jdematt
Okay I have two problems:1.) My car when having constant throttle around 2K RPM jolts and shuttters until i give it a little more gas...then it goes away cimpletely2.) Sometimes when cruising, my Overdrive Light flashes, my car turns overdrive off, and then returns back to its original state of being on.
My car: 1991 Nissan 240sx SE Fastback
Any suggestions or ideas?
Blasin
Car: Import tuning. Car Audio. graphics and interior Work
Could be a number of things.. My has a habit of doing it when its cold..if i let it warm up before i drive it...which i always try to... It runs fine... but Cold its the same way.. Possibly ignition trouble... Mass air flow possibly... on 240s...its always the mass air flow it seems.. On the Overdrive light... Mine does it when i unhook the little sensor on the driver side... Forgot exactly what it is.. check the FAQ for some help.
joe_keyzer
Mine does the same thing at 2k I have yet to find out what it is yet so I hope someone on here knows
I have a 90 Fastback
WAbernethy
Is the idle erratic/high? Mine has a similiar problem. Sometimes if it's idling high and hestitating, I'll stop and pop the hood. If I wiggle the harness, especially near the #2 fuel injector it goes away.
technoman
Car: puss
It sounds like you guys need to clean your wiring harness connectors. Go buy some contact cleaner and clean your TPS sensor conection also make sure you clean your engine temp sensor conection. Clean out every conection you can find. Alot of these problems will go away.
joe_keyzer
I will try that this weekend and let everyone know
Thanks.
-Joe
technoman
Car: puss
Also if your car is older than 6 years. I'd replace th 02 sensor.
zman
My daughter's 1989 240 is having a similar overdrive problem. Only after the light quit flashing, the car will not go into overdrive. A Nissan service guy tells me there is not relay. Does any one have a suggestion.
technoman
Car: puss
I would look at the ECU for the transmission.
