Very odd Car wont start KA help please very odd
mmaxeyjr
Car: 1995 s14
1995 240sx 5spd
New optima red top battery, new brass battery terminals, new battery hold down, new alternator, Close to new ngk plugs and wires.
SOMETIMES when I go to start my car it'll fire right up. Other times (very random) I will turn the key all the way and it wont be anything, not even a click from the starter/relay etc. I turn my key and it just acts like theres a bad connection and the lights go off quick and then turn back on like I was to stall or something.
When it wont start, the only way I can start it is to pop start it then it'll start right up
The odd thing is that sometimes it wont start and then i'll pop start it, drive for a while then park it over night. Then the next morning it'll start up like nothing ever happened. I have new ground wires (ground kit)
Any help?
thanks
Future_gohan
Car: 91 240sx, 91 vert
Starter.
Dazzla
Do you have an alarm? It sounds like the ignition is being locked by the immobilizer. I'm probably wrong but I had a similiar problem to the one I'm describing.
mmaxeyjr
Car: 1995 s14
I dont believe so. If I do it's never functioned. But I have had this problem since I got it. (6 months or so ago)
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Had it with my car, the start signal wire to the solenoid was corroded.
mmaxeyjr
Car: 1995 s14
OutToWinPAHC wrote:Had it with my car, the start signal wire to the solenoid was corroded.
I'll try that, sounds like a definite possibility thanks.
Future_gohan
or the starter.
94_240sx
Car: 94_240SX
Future_gohan wrote:Starter.
That's it.
mmaxeyjr
Car: 1995 s14
if it's the starter wouldnt it atleast click? it's gotta be a poor connection.
Amtk240
Car: 1997 Nissan 240sx SE Red S14, and 1995 Nissan Navan 240sx Ruby Pearl S14.
Common Starter problem is what it sounds like. When it doesn't start like that again, get a broom stick (or something like it) and tap the Starter while someone tries to turn the key in the ignition. If it starts after tapping then it is your starter. If it does not, either they are not tapping hard enough, your starter has gone completely dead, or it is something more complex, i.e. short, wiring, etc.
Future_gohan
My starter went bad like 2 weeks ago, same s***. I won't lie to ya man. Get it done now before it s***s on you like mine did. :]
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
Check your starter grounds.
240_dude
Car: nissan 240sx
It might be the clutch neutral safety switch. Maybe sometimes the pedal doesnt have contact with the switch thats why it wont start. I garunttee you thats the problem lol well...... most likely
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
asoomal wrote:Check your starter grounds.
you mean, the MOTOR?
good suggestion. make sure your motor is in one piece mark. otherwise, the starter may not work
btw, its the starter itself
mrgreeneyes
Car: ///M5
240_dude wrote:It might be the clutch neutral safety switch. Maybe sometimes the pedal doesnt have contact with the switch thats why it wont start. I garunttee you thats the problem lol well...... most likely
his car was not factory 5spd
it WAS auto. til the genius before him decided to attempt the simple swap... and fail... clutch pedal assembly was supported via a wood block w/ duct tape
mmaxeyjr
Car: 1995 s14
but it's fixed now the clutch pedal that is
asoomal
You know what I meant......lol
240_dude
Car: nissan 240sx
So i was right. It was the clutch nuetral saftey switch. Happened to my friend took us 30 mins to figure it out.
mmaxeyjr
Car: 1995 s14
no. we're not sure what it is. i jacked up the car and messed with the wires on the starter and it fired up this morning. so far so good. i couldnt get to the back bolt to tighten the wire it was a little loose. i dont know
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Tighten it. Wobble extension
240_dude
Car: nissan 240sx
Hmm so the starter did not have ground, Wierd probably the wires were loose.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
The engine black is the ground for the starter. The starter has a solenoid on it. Power on one side, load (starter winding) on the other. And a signal terminal that activated the solenoid that also references the block as ground.
Most cars engine blocks are grounded tot he chassis, just like the battery. So there is no need top pull a - reference.
