elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Jul 16, 2005 7:28 pm
Hey Andre, did you end up going to the F1 race??
Anyway, about your problem.... When you adjusted the IAC, did you unscrew the little thing 2 turns out from all the way in?
I think you probably have an air leak as well... in my experience on the Q, air leaks past the MAF cause the idle to be lower, not higher.....
My old Q had this same problem sans the low idle.. At hot startup it would sometimes die, but then it would start right back up.... Unfortunately it died forever beforeI could find the culprit...
Someone had mentioned to me things like the coolant sensor (is yours a federal or california model?)
The reason it doesnt happen when its cold is because everythign is preset on a cold startup... The fuel, timing, and so on... until the coolant reaches 176 or so, the computer adjusts everything by a baseline.. If I understand correctly (take with appropriate grain of salt), once the engine reaches operating temperature, the computer tries to maintain a steady idle, and it assumes you have the baseline IAC set correctly.... Meaning that when you unplug the IAC, RPM should drop 50-100 RPM... Basically, the engine is supposed to idle pretty much perfect and then the IAC is used to make it even more perfect and smooth, and to make it unnoticeable when you turn on the AC and things of that nature...
I would try bumping the IAC up a little bit and see what that does.... Does it do it every time?
