very low compression ..need new engine or rebuild?
1STGen240guy
Car: 1993 nisssan 240sx s13
i have a ka24de and its got 140 in each cylinder it a little worn it have 202k miles on it need to kno if neone have an engine to sell
gumby74
If this is not your daily driver and you have a place to work, rebuild your current engine.
tramp_drift240
Car: 1992 240sx SE Coupe
ive heard if you put some oil into the cylinder then do a compression test, if the numbers read higher, its the rings or cylinder walls. if its still low, it'll be the valves.
if anyone can valiadate that procedure, you should try that to narrow down what it could be.
azn_b110
U WOULD RATHER HAVE IT REBUILD ITS BETTER AND STRONGER
AZ89two4Tsx
140's aren't bad are they?
Here's a link to another post......
zerothread/327967
pinky121388
Car: 1992 Nissan 240sx convertible
AZ89two4Tsx wrote:140's aren't bad are they?
zerothread/327967
yea 140 isnt real low,, but i heard from numerous times that u shouldnt turbo your car unless ur at a compression of 150. but rebuilding is the best route, get some bad *** internals and boost the hell out of it.
