Very high pitched whining sound
BP-1-3333
Car: Nissan ZX 300 Z32 Twin Turbo
I have a 1990 ZX 300 Twin Turbo automatic. It has just crossed 11,500 miles.
When I cross 60 there is this very high pitched whining sound. At this point the PSI crosses the 0 mark towards the +14 meter. The very high pitched whining sound fades away as the PSI crosses 0 back towards the -14 meter. I have no access to a Nissan service center and the garages here are pretty basic, but should be able to do what needs to be done if I can point them in the right direction or possibly do it myself if I can be instructed.
Can anyone help?
awesomekasim
Car: 1991 300zx TT 5spd
Does it happen only when you cross 60?? If you say it happens when the turbo psi is higher than 0, then that means its happening while the turbos are spooling and you are going into boost. But you can go into boost under 60.
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
BP-1-3333 wrote:I have a 1990 ZX 300 Twin Turbo automatic. It has just crossed 11,500 miles.
Can anyone help?
Sounds like a boost leak
BP-1-3333
You are correct, as you said, "it happens when the turbo psi is higher than 0, then that means its happening while the turbos are spooling and you are going into boost."
The sound only comes when the 0 mark is crossed. It's not dependent on going over 60.
Can you tell me what to do?
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Can anyone help?
Ummm, Do a boost leak test
minlow88
Car: 93' 300z big piece of N/A
08' altima coupe
88' 4x4 s10
82' 280zx
Does the car run alright? If it runs fine, I would consider the sound of a turbo more of a whilstling sound than a whining sound. but what would i know, i have an n/a. lol.
i thought a boost leak would cause some hesitation or cut or somthing.
CrazedZ32Owner
Car: 91 Z32 TT(no motor), 2008 350Z Nismo, 05 Pontiac Sunfire speed machine!!! :)
a boost leak or any kind of vaccum leak would not allow the car to hold boost very well ( no duh right?? lol)... so i dont think it is a boos leak if the car is boosting fine..... TO OP: it is boosting as it should right??
BP-1-3333
Thank you all for you input and advice. I have been checking the hoses and they were very loose. All I did was tighten the screws on the hoses and used the diagram outlined in the forum and got it sorted. The sound was similar to a whistling sound.
Many thanks.
BP-1-3333
The sound is still there. I opened up the front panel and tightened the hoses and did the ones on the engine and that high pitched whistling sound is very much still there!! Has anyone had this problem or can recommend something else?
BigTDogg (MA)
Is it a honk or a whistle? Goose honk is very common. Whistling is a boost leak. There are more hoses to tighten.
BP-1-3333
It's a whistling sound, only happens in second gear and D. I'll check for more hoses. Thanks again!
BigTDogg (MA)
BP-1-3333 wrote:It's a whistling sound, only happens in second gear and D. I'll check for more hoses. Thanks again!
Follow the compressed air charge from the compressor outlet all the way to the throttle bodies. There are about a dozen clamps, per side.
