very easy inexpensive way to bleed brakes by yourself reliably
slyedog240sx
Car: 93 240sx se coupe, 05 grand cherokee HEMI Power
I used this last night to bleed my brakes after i let the lines gravity bleed to flush the system.Worked very well.For 8 bucks each they are easier ,and cleaner than speed bleeders.Less messy than stick some tubing in a bottle of fluid.http://www.otctools.com/produc...=1530
S13Joe
Car: 92 Coupe
thats a f_cked up sig... ow.
thanks for the info too, i'll probably be doing this soon.
tercel drifter
Car: sr20det s13
makes sense, 1 way chekc valve. cheaper then having a friend over then buying him beer lol
dtowndrifter
Car: s-14 kouki
you purchased it online?
slyedog240sx
dtowndrifter wrote:you purchased it online?
No i run a parts store and bought 4 of them through work.Any parts store should be able to get otc tools.Even sears can get them i think.Should run around 8 bucks retail.
tramp_drift240
Car: 1992 240sx SE Coupe
i dont get it. do a write up or somethin on how you actually use these.
since it basically just seems like an elongated rubber speed-bleeder.
Dattebayo
tramp_drift240 wrote:basically just seems like an elongated rubber speed-bleeder.
Yeah, and how exactly is that cleaner than a hose and bottle? It's just the same thing as hose and bottle without the wrench... and you still need a wrench in the beginning anyway.
MastaYu
Car: 92 Nissan 240SX SE HB
im confused also at how it works
slyedog240sx
it's simple guys.It has fingers on the end that attaches to the bleeder screw with a washer that slides over them to lock onto the bleeder screw.You twist the bleeder 1/4 to 1/2 turn.Attach hose, lock fingers on, stick other end in a bottle.Pump till pedal feels good, tighten bleeder and you are done.It's cleaner since you aren't disposing of a bunch of wasted fluid from a bottle and there is no way air can come back in.I don't have time to take my wheel off to do a writeup right now but will someday when i have time.It is basically a speed bleeder with a hose attached.I work on a few vehicles on the side and it is useful in that aspect.Plus it is cheaper in the long run for multiple uses than buying speed bleeders for every vehicle you workon.
