Fenvy »
https://forums.nicoclub.com/fenvy-u13048.html
Wed Feb 14, 2007 11:18 pm
I remember someone on fresh alloy stated that the stock grounding of coil packs is pretty bad. I checked the resistance awhile back with a multimeter and it doesn't look so good. I don't even the exact numbers though. Since phase2 sells a product to combat bad ground, I suspect this is a common problem. You can fix it without spending like 90$ for their grounding plate
Set your multimeter to resistance mode (omega sign) and choose 2000. Check between battery ground and the screws of the coilpacks, if the number isn't 0 or 1 then you probably want to do this simple and cheap fix.
Basically you need:-2 ft of wire loom, probably 3/8 ID or 1 size bigger...-some stranded wires, prefer same size/black color, 12 to 16 gauge should do. If you don't have it in a roll, buy like 10ft since it is so cheap anyways and you can use the extra on something else-wire stripper for the said gauge wire-1 ring connector big enough to accommodate the typical 12mm bolt on 240sx and the 4 wires combined.-soldering iron and some solder, any type is probably fine.
1) find a good spot on the firewall for grounding, look for any bolts you can remove. There should be a few right in the middle of the firewall.
2) Use the wire to measure the distance from the said bolt to each of the 4 coilpack mounting screw, then cut 4 pieces of wires in according to the rough measurement with a little extra wires to spare
3) you should have 4 unequal length wires, strip one end of each wire by about 2cm to expose the strand. Twist the strand with your hand and use the soldering iron to apply solder to all 4 exposed and twisted strand (this is to prevent splitting and to make the tip stronger) It is possible to use ring connector instead or other connector but I could not find the right size that is small enough.
4) secure the wires by each of the coil packs mounting bolts. Wrap the wires in wire loom and pull it toward the ground, cut the other ends of the 4 wires so it will be equal length. Strip to expose the strands, twist all 4 strand together and cramp it to the ring connector. Then mount it to the firewall.
5) You may want to secure the wire loom with zip ties and check the resistance again at 2000 setting. It should now read 0 or 1. You can also use 200 for better reading.
I noticed immediately that the funny idle I had is gone with this. Have not had the chance to drive the car yet since I am doing other stuff.
