very bad camber is owning my life
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
with eibach sportline and tokico hp blues, i have really bad camber, fine my car is said 2 handle better, watevers, its eating away my tires, ive gotten a camber kit on the front right, it was reduced from -1.6 to -0.7, the rest were jus bent into correct angle, i had -2.3 on the rear left, now its -1.8, and its still eating away my tire like crazy, ive already had the tower bent 2 the safest angle the guy said was possible, wat should i do now??thanks again guysseto
McRussellPants
Car: 92 240SX
Whats your Toe set at?
Toe kills tires, camber won't be noticeable unless your trying to run the same tires for 20K+... in which case stop driving like an old lady.
S3t0_S13
0.08 for the rear left and right
McRussellPants
Car: 92 240SX
How many miles are on it.
.7 on the front won't kill tires... at all.
the rear should still be good, unless its .08 out.(which is unlikely since that would be retarded). You must have alot of miles on them, just swap sides for the rear tire.s
S3t0_S13
right now the rear camber is 1.8 on the left and 2.0 on the right, and its the left one thats getting messed up, its negative so the bottom part of the tire is toward the inside, negative camber, no these tires have less then 3K miles on them, falken ziex 512
heres how the setup is right now
Left Front Right FrontCamber -0.7 -0.7Caster 7.1 6.9Toe 0.06 0.06
Left Rear Right RearCamber -1.8 -2.0Toe 0.08 0.08
This is after all of it was aligned and fixed, it was all much worse then this before, the camber on the rear left was -2.3!!!!
180fan
Car: 89 fastback
i'm rolling on alot more camber than that. that's nothin.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Get yourself some adjustable RUCAs. Most people get them from SPL.com, but i have JIC Magic (yeah, im a JDM boy, flame on). They should be in the neighborhood of $260 for the pair ($300 for JIC, $360 for Cusco), but you can get that camber well under control.
S3t0_S13
cant it be jus bent and knocked into place?i dont really have the money to get 300 dollar camber kits, cuz im not gona be adjusting my tires for track, jus everday use thats all
