ok...heres the story...i bought my vert about 3 monts ago..i did a 5 lug swapped from a 95 240sx se...there was a little bit of problem with the front....the shocks are s-14 and the s-14 bolts don't fit.....so i used the s-13 bolts(which are slighlty smaller and they fit) with the s-13 bolts, whenever you turn or drive, sometimes the car crank or make some noises.....i was thinking of drilling the shpcks slighty bigger to make the s-14 bolts fit or buy the shock mount spacer for 240sx on ebay...
if you don't knowat they are, go to this site...
NEED ADvicE ....
http://cgi.ebay.com/ebaymotors...ZWD1V
