Verticle Cargo Net for 2015 Rogue
Vidarious
Hey All,
I am looking for a cargo net to prevent items from falling out of the truck when opened. Nissan has an official accessory which is horizontal and pins down items but I am just looking to create a barrier to hold items in when they get shifted around and the trunk is opened.
I've tried searching but I've come up dry. However I may just be looking for the wrong item.
Any suggestions?
kapesports
Car: 2015 Rogue - 2015 Altima
i dont think the rogue has the ability for it since it does not have the proper hooks for them. the pin down style net is the only thing that you can use factory- wise.. otherwise you have to improvise..
Can you not use the divide n hide functionalities?
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Probably not what you're looking for but...
Amazon: trunk cargo organizer http://www.amazon.com/s/ref=nb_sb_ss_i_ ... izer&ajr=0
whizkidtn
Car: 2014 Nissan Rogue SL (AWD), Premium package
Vidarious wrote:Hey All,
Any suggestions?
We have the same issue with our 2014 Rogue SL w/cargo net. The "Divide-n-hide" is about the next best thing to do and works relatively well for what it is. Like you, I still would like a decent vertical cargo net option to install and use in addition to the "Divide-n-hide" boards.
If you find something you like and seems to work well, please update this thread and let us all know about it! Thanks!
khulk
Car: 2015 AWD SV Rogue with Premium Package
I'm not sure if this will help any of you (it depends on how large your items are). But how I almost always have my Divide n Hide is when I open the trunk I lift up the panel closest to me and position it vertically in that first section. That way (usually when I have groceries), everything in the first section stays put and doesn't fall out/over. Everything in the second section (closest to the second row) doesn't fall forward, because the top section is blocking it.
Let me know if that doesn't make sense and I can try to upload a picture of what I mean. Good luck!
whizkidtn
Yup, we do the same. I'd just like a nice vertical cargo net to supplement the Divide-N-Hide for certain items.
kapesports
I made my own hook mounts. folded the floor/cargo net and made it as the trunk net...
whizkidtn
Looks good. What hardware did you use and how did you attach this to the plastic panel? Many thanks!
kapesports
got the hardware at target ;) ... i think they are called d-rings.. rigged screws and support for the back plastic pannel for support...
Knob
Car: 2015 Nissan Rogue S 2wd
kapesports wrote:got the hardware at target ;) ... i think they are called d-rings.. rigged screws and support for the back plastic pannel for support...
Nice Kapesports! can you post a DIY with pics/names of exact screws, etc etc etc. I know D rings but what screws? Did you just drill into plastic? etc. Thanks
Return to “Rogue Forum”
