lino »
https://forums.nicoclub.com/lino-u31679.html
Thu Dec 15, 2005 3:23 pm
My 1991 Q45a has the ACTSUS (Active Suspension Warning Lamp) light lit up on the dash and the car does not raise. I had all 9 of my accumulators replaced and after doing a Self-Diagnosis and also connecting the CONSULT 2, I get the same message:VERTICAL G SENSOR FRONT FAULTY- MALFUNCTION CODE 15
On the CONSULT 2 printout, I got a reading of 1.83. According to the Factory Service Manual page FA-72, it says that if there is continuity when the test is performed, then the Vertical G Sensor is faulty. The mechanic who tested the sensor said that there was continuity.
So does that mean I need a new Vertical G Sensor? If I buy a new sensor, will that allow my car to raise?
Before I replaced the accumulators, the car had a harsh ride, but would still rise.
Modified by lino at 3:56 AM 12/17/2005
