vert vs coupe
d3vilskid
Car: 240sx '95 coupe
so with the vert almost everything are different then the coupe. If i was to change the brakes to 3zs and get the rims for the 3zs are there anything different I need to do to the verts or is it the same as the coupe?
A vert IS a coupe.
With the top lopped off.
The vert had ABS (larger) rotors, but that's it mechanically.
p.s. What is"3ZS"?
d3vilskid
3z is the 300zx that is all, so the suspension is like almost the same, cause i want to change the brakes to 300zx brakes and use the rims as well.
Fenvy
Car: 2005 350Z Base 6MT
I drive a 2.4x but in japan they call it a 1.8x
my dream car is a 2.8z though
Hijacker
Car: '92 240sx Convertible
'94 F-150
the chassis is the same between all trims of the S13. What can be done on a coupe or a fastback can be done on a vert. If you do the 5 lug swap, it's the same as on a coupe. Same with the brake swap, or any suspension work.
