Wished I had that option. Right now the OEM deck display is basically gone. And 2 speakers are blown, the other 2 aren't far from it.topless94 wrote:I've only put in a new head unit...speakers will go in later on.
Sweet, had no clue there were pre-made adapters. I was just gonna make some. I've already ordered the 5.25s for rear and 6.5s for front, I'll need the room in the rear to mount the tweeter anyway.BaconLuver wrote:fronts are 4x6 and if you want to install larger speakers, you need these adapters: http://cgi.ebay.com/Install-La...wItem
Rears can accomdate either a 5.25" or 6.5".
funny you say that..biggie wrote:
EDIT-- Anyone bought those and got them? Seller had some bad feedback on the ones for the 240, item never recieved. Scares me.
thanks
Cool, I'll try them. I'll blame yall if I get screwwed.Eikon wrote:I bought them as well. They are perfect! Had no problems at all!
So you are saying 6.5 for the front and 6.75 for the rear is good combo for vert?WoDan23 wrote:uhh yea....i replaced my speakers 4X6 up front and 6 3/4 in back, most 6.5 will fit though with the outer brackets, check crutchfield, and dont go 5.25 in back when you can go 6.75, you wont get enough bass especially since its a vert.
I'm doing 5.25s in rear with side tweeter. But I'm doin a 10 or 12 in trunk for bass, so that should balance it out.WoDan23 wrote:uhh yea....i replaced my speakers 4X6 up front and 6 3/4 in back, most 6.5 will fit though with the outer brackets, check crutchfield, and dont go 5.25 in back when you can go 6.75, you wont get enough bass especially since its a vert.
