biggie wrote:There is some support cutting that will need to be done to have room for the adjusters on the rear coilovers.
I just have springs/shocks, but have heard of D2/megan/stance(?) that don't have the room for the dampner adjuster knob on the top unless you cut out a little on each side.jspec603 wrote:
What brand were/are you using? I don't have this problem with my Tein. Then again, there is not a separate adjustment tool required to adjust dampening. The EDFC unit however will not fit because of the top.
very true with the megans but i was able to put them on without cutting that little piece. the only thing now is i cant adjust it nowbiggie wrote:I just have springs/shocks, but have heard of D2/megan/stance(?) that don't have the room for the dampner adjuster knob on the top unless you cut out a little on each side.
