vert rear quarter windows...
rhatmonkey
Car: Nissan 240SX Convertible
so i got my vert almost a year ago and when i first got it, dropping the top also dropped the rear quarter windows; however after my alarm was installed it doesn't do that anymore. i went through and checked, there are no cut wires, nothing not connected,.. everything looks like it should. i can even use the switch in the center console to raise and lower the rear quarter windows.
so i guess my question is, how do i fix that? better yet, if it's possible to wire all the windows to the top down switch that'd be even better.
thanks in advance
onosqv
Car: '92 240sx Vert
Well, if it happened after installing your alarm, my first suggestion would be to uninstall the alarm to see if it still happens.
The only other way would be to go through the troubleshooting section in the vert fsm supplement (I believe someone has uploaded on here if you don't want to buy one).
Loki
Car: 1994 Nissan 240SX Convertible
2010 Toyota FJ Cruiser
2001 Ford F-150 SVT Lightning
This isn't some problem being caused by the Window Lock button on the driver's door panel, right? Was this just an alarm install, or alarm and keyless entry?
onosqv
Car: '92 240sx Vert
If that was the case, wouldn't the center console up/down switch not work?
And I think the rear quarters still go up/down when you do the window lock w/ the top up/down button - not 100% on that tho, I should try that tmrw, haha.
rhatmonkey
Ok, so here's more info (based on the statements thus far)
1. i did try removing the alarm, didn't help2. the window lock switch isn't engaged, the windows roll up and down fine.3. the rear quarter switch operates the rear quarter windows just fine
basically everything works great,.. or atleast appears to if you didn't know the rear quarter windows were supposed to go down with the top.
Loki
Yeah, but I like to eliminate the simplest problems.
Hope this will help you somewhat.
