onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Mon Dec 29, 2008 11:03 pm
It's been a while since I've done mine, but I don't think you even have to remove the entire fan shroud, just unclip the "21477" part below by hand - that should clear the fan.
If you do need to remove the shroud and can't find the radiator shroud clips/screws, remove the fan assembly; it's just another 4 nuts...
With the fan out/movable, you can either try to pull the radiator again, or you now have more room to look for the remaining screws/clips - which is basically all pictured in the diagram there (just search each corner for a screw/clip).
It's not all that hard, you just need some patience & a light.
