Fel1 »
https://forums.nicoclub.com/fel1-u38813.html
Sun Apr 02, 2006 7:05 am
First I want to thank everyone who responded, this is what I found..The oil for the pump in the vert (For the TOP) is ok maybe is half full, what I did notice after a small inspection is that the TOP seems to have somthing that looks like a Strut??On both sides? The right side seems to be broken? The reason I say that is, the left side (driver side) seems to be attached to a bolt, could this be keeping my top from working? And if so, is this hard to fix (Expensive?) Once again I appreciate all responses, Also regarding the headlamp, I did the manual thing and got it down, when I press the button for it to go up it does, however it still will not come down what could it be?Thanks to all.
Modified by Fel1 at 10:23 AM 4/2/2006
