vert leaking gas
starion1991
Car: 1994 nissan 240sx vert
So ive noticed a smell of gas in my car after i replaced a dying fuel pump, thats due to the tank seal, it wont seal right.
So a few days ago i went into my buddys apartment complex and i got out for a second and noticed a trail of drips to a pullde under my car. I thought it was oil, and checked it out but it was ok. So i touched it and it smelt like gas. I checked the lines running from the fuel pump and they look OK to me. any thoughts/ ideas on what to check out
94_240sx
Car: 94_240SX
You must replace the seal(large o-ring). I thought I could reuse it but it expands over the time, so it won't go into the slot properly. I bet when you drive around gas comes out through there and you saw the drop. You might want to check those 2 fuel lines that you had to remove when you replace the fuel pump. I'm positive it should be one of those.
GoinTopless240
Car: 1993 Nissan Sil40 Vert
2008 VW GTI
2010 Infiniti EX35 bought in 2019 (15,000) miles
What he said... and lucky for us that part is dealer only part (at least when I did mine it was). Good place to start.
DeXteR
Car: '14 Nissan Titan Pro4X
'05 Nissan Xterra OR
'92 Nissan 300ZX Slicktop
'94 Nissan Sentra RS Rally Car
The pump seal is relatively inexpensive as well... surprisingly.
I agree, replace that seal and check the lines on the top of the pump.
ccptravis
Car: 240sx convertible
mine leaks gas too. i believe the problem with mine is the tank itself. it could be leaking at the seam of the tank. when i drive it in the rain, water gets in it. LMAO my vert is such a piece.
94_240sx
Car: 94_240SX
Here's the part number. I think it was in $5-$10 range from the dealership. I put some grease to seal it tight.
