Vert have different dash wiring?????
DropTopRB
Car: 1993 240sx convertable, RHD, chargespeed s15 front end and wide body full kit, powerd by rb25det
Ive been working on wiring a rb25 into my 94 vert, and when it came to the dash wiring i found that all of the wire colors are different then in any install links ive found for any engine install into the s13. Anyone else notice this, and are the pins still the same, just different color wires???? Any info would be GREAT! Thanks!
DropTopRB
anyone have any info???
madcowvert
there is only one plug in the dash that you would need if your doing a rb25 or any swap for that matter. and its the white plug that gives signal to your gauges.
DropTopRB
I know the plug, ive done a few sr20 swaps, its brown in my convertable though i believe, and the wire colors are different....
madcowvert
I have an rb in my car and i'm almost sure there the same. when i put in my rb the harness was already done for a single cam i cut the sohc plug off and macthed it to the dohc one it worked fine. if you want tommorow i'll take a picture so that you can see it.
And yes i looked at the fsm for the verts it has the exact same dash harness
Hijacker
Car: '92 240sx Convertible
'94 F-150
My dash plug is white as was every convertible I've done an SR swap on.
DropTopRB
so i went and doubled checked last night and its definatly brown. My cars mf date is 3\93, and the wire colors are different, i have no idea what is going on...someone must know whats going on with this. I JUST WANNA GET IT RUNNING!!should have kept the sr i guess....
nis-s13
yeah i have the same problem the sr harness is a white plug and my dash plug is brown... i need to figure this out a.s.a.p.
nis-s13
don't know what happen to my post but sorry if its a re-post...
i have the same problem my sr harness is a white plug and my dash harness is a brown plug. what do i do? do i cut the white plug off and splice in the brown plug or do i do the opposite? Help!
I need to figure this out a.s.a.p.
madcowvert
you need to cut the brown plug from your engine harness and the macth the colors to the sr one it's very easy.
for more details
http://www.nicoclub.com/articles.php?id=162443
nis-s13
so i have to cut the brown harness from the stock harness then color match it to the sr harness???
madcowvert
nis-s13 wrote:so i have to cut the brown harness from the stock harness then color match it to the sr harness???
yes thats what you need to do.
