honeybus wrote:I recently replaced the alternator, so I imagine it might not be this problem, still, it is an idea to double check. The new batteries he was using was just jumpered to my existing installed 'dead' battery, and not a full replacement.
It's a good idea to replace the battery with a new one when an alternator dies (unless the battery is nearly new). A bad alternator usually kills a battery in short order because the charging system is constantly switching between alternator power and battery power. Discharging the battery with the key in the ignition might have been the thing that finally did your battery in.
Costco sells high quality (Kirkland brand, but they are made by some big OEM) batteries for around $50 if you have a membership. If you don't have a membership, you might want to consider getting one since it's a good value and there's one in your city.
The combination of weak battery and damaged injector might be the source of the problem. You could be losing spark while spraying too much fuel into a cylinder.
You might want to consider getting rebuilt injectors. They are around $200 for a set, and usually are built so they can handle ethanol fuel, unlike the ones that came with the car. I think ethanol is common in VA (at least I've seen it when I've stopped for gas there).
I'm not sure where you normally get your car worked on, but I usually go to "Cho's Auto" in Old Town Gaithersburg for anything not-240SX-specific that I can't do myself. They only work on imports and never jerked me around.
Nice meeting ya, wish I could've seen your vert, though! Oh, here is the place in NJ that does AT to MT swaps:
http://www.powerzamcam.com/services/
