There are few parts that the dealer's computer will tell you are the same. Most vert P/Ns will almost always go through as vert only.94_240sx wrote:BTW, I called dealership to ask some questions, and vert has a different part number for the catalytic converter.
If that's from the Catco, it doesn't matter. As long as somone sees a cat on there and not just an empty tube they'll pass the inspection.cmkelly wrote:Does this quote bother you?
**For off-road use only, due to the nature of this item**
That's there to get the company out of liability. Most of my car is considered "intended for off-road use only". I guess about the only thing that is good for on-road is the chassis and body work. For now.cmkelly wrote:Does this quote bother you?
Try to buy some aftermarket suspension parts. All of them say "off road use only." I've searched, and Catco catalytic converter works just fine.tenkawa_akito wrote:
