MIdnkight-lude »
https://forums.nicoclub.com/midnkight-lude-u15551.html
Wed Nov 14, 2007 8:07 am
truthfully even a bolt on turbo isnt safe.
My former Boss, who owns a CAR SHOP. had a greddy bolt on turbo on his Civic Si beat the living **** out of it. it lasted a good year, maybe year and half. after he remove it, and remove the engine, he had already lost two piston rings. and god knows what else was done to teh engine. unfortunelly for you, you dont have access to a shop that can pull a motor for cheap. and then repair the motor for cheap. TURBO isn't slap this and that on, and hope it runs.
Like i mention choose 2 of the 3, cheap, reliable, fast. most ppl go cheap and fast...
Now, if you didnt get it before, it hard to do a custom turbo manifold because to access the engine bay while the tube are on the car is hard. if you have ever look from underneith the car, there is very little room. Using the stock manifold would work. but yaaa......
Like i mention in the other thread, get it done right, and you will be more happy, and your car will last a lil longer. but still expect to shell out 5-8k for someone to do it. go around to all the speed shop and ask for a quote.
oh i forgot to mention unless you know someone expect your car to be in the shop for close to 3weeks to 3 month.
and the regular issue that can pop up, let not talk about. my friend's supercharge prelude has been in the shop more then it has been driving. >_<
