Versa/Tiida Head Grille Mask
jarambulo
Car: 2008 Nissan Versa SL 1.8
I browsed through ebay and found a nice grille for the V. I noticed some slight differences on the bottom of the hood/lip. My question to all is: will these grilles fit them???
Here's the link: http://cgi.ebay.com/ebaymotors...l1247
jfanaselle
Car: 2007 Nissan Versa Hatchback SL, 2008 Nissan Rogue SL
The vehicle in the picture is a Nissan Tiida, not a Versa (notice the steering wheel on the right side instead of the left). To the best of my knowledge, this grille will not fit, as the hood on a Tiida is shaped slightly different to accomodate the different grille.
Someone else could probably chime in with some more detailed info, but there has been alot of discussion on this board about the difference in the front ends between the Versa and Tiida, and i'm 95% sure this grille won't work unless you convert the entire thing (hood, grille and bumper).
KimberKenobi
Car: the Camel
Here are my thoughts... they should be the same width as the sides of our grill and should be roughly the same height... ask for specific measurements and then measure the appropriate part of your grill. If you cut the centerpiece out of your grill and attach it, then find a way to attach those pieces, it could work as long as you're sure that the dimensions are the same.
Worst case scenario, you're out $100. Makes sure you can attach them to the car before you hack your grill apart.
