Versa Stop Light Bulb Replacement, How do I access right tail stop light bulb
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
ZinLover
Car: 2007 Nissan Versa SL
Versa Stop Light Bulb Replacement, How do I access right tail stop light bulb for replacement. The owners manual is very unclear.thanks,
rwanttaja
ZinLover wrote:Versa Stop Light Bulb Replacement, How do I access right tail stop light bulb for replacement. The owners manual is very unclear.thanks,
You gain access to the screws holding the assembly to the body from within the truck area. Open the hatch and look at the inside of the rear corner. You'll see a set of plastic caps. Use a screwdriver tip to pry these away, and you'll get access to the nuts holding the taillight assembly in place.
I had a brake light quit working. When I mentioned it to my dealer, they said the bulbs were covered under warranty. They found the stoplight bulb was merely loose, not burned out. They re-installed it, and it's worked fine since.
Ron
ricks350z
u need a 10 mm wrench, 10 mm long socket, flathead screwdriver.
pry out 2 opening..one opening is covered by wire, just pull it out..go outside the car and pull it out carefully..dont worry u wont snap anything.
done
Modified by ricks350z at 2:54 PM 11/21/2008
rockie2008
Car: nissan versa 2008
I need a little help about this one too.
I took the two bolts off the screws from the inside but it is still not giving. I did a little reserch on it but its telling me the same thing I have allready done. I ended up pulling off the plastic case on the inside and theres a plastic thing on the inside connected to the light case and its not coming off... i dont want to break it so help me out please.
sorry its a little hard to explain it, it would be better if i could show you. i have only had this car for about 7 months. just trying to get it fixed.
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
i would recommend buying these http://shop.versaspeed.com/pro...yId=4 a little pricey yes, but they are LED so they will last you almost forever... i have had them over a year and still going strong!
versanewb
Car: Versa SL
Are you telling me that the entire tail light assembly has to be removed to change the bulb???? While the hell didn't they just make an access panel that you can reach in and change the bulb like every other car manufacture? If you pull the headlight assembly out won't that break the seal and eventually cause a leak??????
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
yes, you need to remove the tailight assembly from the car to change the bulb. Beyond the screws, they are snapped itno grommets on the body that keep them retained. That's why they are hard to come out. You need to pull them rearward to get them out of the grommets. You don't break any seals on the light assemblies by removing them from the body.
Return to “Versa Technical Discussions”
