Versa specs released...
2007 Nissan VersaKey Dimensions and Specifications Engine 1.8-liter DOHC inline 4-cylinder122 horsepower @ 5,200 rpm127- lb-ft torque @ 4,800 rpmBore and stroke 84.0 mm x 81.1 mm Transmission Available Nissan Xtronic CVT (Continuously Variable Transmission)Available 4-speed electronically controlled automatic with overdriveStandard 6-speed manual Gear Ratios CVT 4AT 6MT 1st (CVT Low) 2.561 2.861 3.7273 2nd - 1.562 2.1053 3rd - 1.000 1.4516 4th - 0.697 1.1714 5th - - 0.9714 6th (CVT High) 0.427 - 0.8108 Final drive 5.473 4.072 3.9333 Reverse 2.689 2.310 3.685 Platform Nissan "B" platform Drive Configuration Front engine/front-wheel drive Suspension Independent front strut with coil springs, stabilizer barTorsion beam rear suspension with stabilizer bar Steering Electric power steering Brakes Power-assisted front vented disc (11.02” x 0.95”/280 mm x 24 mm)/rear drum with available Anti-lock Braking System (ABS) with Electronic Brake force Distribution (EBD) and Brake Assist (BA) Wheels/Tires 15-inch wheels and tires, available 6-spoke aluminum-alloy wheels; P185/65R15 tires (33 psi) Wheelbase 102.4 inches Track (front/rear) 1480 mm/1485 mm Length 169.1 inches Hatchback; 175.9 inches Sedan Width 66.7 inches Height 60.4 inches Coefficient of Drag 0.31 Select Exterior Features The 2007 Nissan Versa optimizes packaging efficiency through use of a long wheelbase, short overhangs and aerodynamic design. Its sporty, personal styling is highlighted by body-color front and rear bumpers, large headlights, Nissan signature grille and body-color dual remote–controlled outside mirrors. Seating Capacity 5 passengers Front Head Room 40.6 inches (without sunroof) Front Leg Room 41.4 inches Rear Head Room 38.3 inches Hatchback, 37.9 inches Sedan Rear Leg Room 38.0 inches (15.6 inches rear knee room) Shoulder Room (front/rear) 53.5 inches (1360 mm)/50.7 inches (1287 mm) Interior Cabin Length 72.3 inches Interior Volume 94.4 cubic feet Hatchback (without sunroof)93.9 cubic feet Sedan (without sunroof) Cargo Volume 16.9 cubic feet Hatchback (with rear seats up)13.8 cubic feet Sedan Select Interior Features The 2007 Nissan Versa offers an outstanding combination of roominess, amenities and utility. The spacious cabin is complemented by a high quality interior design with soft-touch materials and comfortable seating. Available equipment includes Intelligent Key, Bluetooth® Hands-Free Phone System, satellite radio and Rockford Fosgate-powered subwoofer. Safety Zone Body construction with front and rear crumple zones Advanced Air Bag System (AABS) (includes dual-stage front supplemental air bags and front seat side-impact supplemental air bags for chest protection), standard Tire Pressure Monitor System (TPMS), available roof-mounted curtain side-impact air bags for front and rear outboard occupant head protection, LATCH (Lower Anchors and Tethers for CHildren) system, child safety rear door locks, child seat upper tether anchor, front seat Active Head Restraints. Fuel Economy (combined) Estimated 38 mpg (with CVT transmission) Recommended Fuel Unleaded regular (87 octane) Fuel Tank Capacity 13.2 gal (50. http://www.nissannews.com/niss...shtml
l31nismo
Car: 2002 Nissan Altima SE Nismo 3.5 5spd MT
2005 Nissan Sentra SE-R Spec-V
allright a pocket rocket with a murano transmission. That would be cool. I can't wait to see what the aftermarket does with a CVT. Don't plan on doing too many burnouts though guys.
jdmser
Car: duh
so I have to ask, will the QR25 fit
penpen-commander
CHIBI MURANO!!!!
shreqboi909
Car: '98 ej8 R.I.P 07 nissan versa/tiida
does anyone know the compression on the versa???
Spa2k
shreqboi909 wrote:does anyone know the compression on the versa???
The engine's compression ratio is 9.9:1, if that's what you're asking.
motoguy128
Car: 2007 Nissan Versa S - 6 Speed
The compression is probably low enough and the relatively short stroke should allow for reliable low pressure supercharging. I believe a kit may already be available overseas.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
That's correct. Impul makes a very small roots-type supercharger for it.
gtr_rider
Spa2k wrote:The engine's compression ratio is 9.9:1, if that's what you're asking.
Thats quite the compression for such a car, does nissan have something coming up for the Versa?
airboss
Car: Versa
Does anyone know what are the rims specs? 15X5.5? And the hole pattern, 4X4.5? I would like a cinfirmation from someone who know's. Called the dealer and they were not sure yet ?
