Versa Speaker Wiring
hammer_tim
Car: 2008 Nissan Versa
First off - I apologize if this has been discussed in a previous post - I searched and searched but couldn't find anything.
I am wanting to splice into my passenger side back door speaker. Is there a wiring diagram available anywhere? All I need to know is what color wires I need to splice into? I know I could remove the panel and look at the speaker - I figured this would be easier though.
2008 Versa SL - 6 Speed - PW/PD (about 8 wires bunched together)
Thanks for your help.
Modified by hammer_tim at 7:28 PM 1/4/2008
xtwoonamatchx
Car: 2007 Nissan Versa S
to be totally honest, i forget which color was what... even tho it was less then a week ago that i installed speakers, but if you need to know, pop off the panel and the wire closest to the front is ground....
you could always hook it up one way, and keep trying til you get it =p
not the safest way, but it does the job. haha
good luck, what are you installing?
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
You can look in the service manual, available here on the website.
According to the manual, at the speakers the wires for both are light green for positive and green for negative. At the harness connector (M43 on the head unit), the left speaker is pin 4 (violet) for positive and pin 5 (red) for negative. The right is pin 13 (light green) for positive and pin 14 (green) for negative.
If you're coming off somewhere else in the harness, you probably should check the manual to be sure. (At one point it changes to white and red for the left speaker, and then at another to the light green and green found at the speakers.)
Modified by kc5f at 8:10 AM 1/5/2008
scooterbob
Car: 2008 Versa, 1995 200sx
http://www.nissanversa.org/generalfaq.shtml Check under "Factory Service Manual". (Hopefully the link works)
