Versa S with audio auxiliary?
frer
Hi,
I have a Nissan Versa S with the basic radio installed. I was wondering if it is possible to connect an auxiliary player to the back of this radio. I know the SL model has an auxiliary input jack in the front but I also read that some basic radios have jacks in the back that you can hack to plug in an ipod or other audio system.
Is this possible? If so how can I remove the panel to have access to the back of the factory radio?
Thanks,
François
versabundus
Car: 2007 Nissan Versa
Nope not Happening. You can go with the FM transmitter. Not very good though.There is a new FM converter that hooks up directly to your antenna input. It's supposed to be better, but I haven't used one.
MiXMa5TaMaX
Car: Nissan Versa
I tired to get the fm input device to work, but the versa's system doesn't have an antenna jack... so no luck w/ that
XterraVersa
Car: 2002 Nissan Xterra
Nissan 350Z Nismo
MiXMa5TaMaX wrote:I tired to get the fm input device to work, but the versa's system doesn't have an antenna jack... so no luck w/ that
Yes it does. But it is not round like old stereos. You need an antenna adaptor.
MiXMa5TaMaX
Car: Nissan Versa
XterraVersa wrote:Yes it does. But it is not round like old stereos. You need an antenna adaptor.
orly?
are there specific ones for the versa, or is it a universal adapter, and where can I get one?
frer
Interesting...can you guys give me an example of a "FM converter" and the "adaptor" needed so I can start shopping for them
Thanks a bunch!
François
Modified by frer at 10:59 AM 12/30/2006
versabundus
http://www.walmart.com/catalog...10460
info about others, including wired(direct through antenna)
http://www.crutchfieldadvisor....age=3
