ffmpr604 »
https://forums.nicoclub.com/ffmpr604-u122776.html
Sun Jan 18, 2009 10:32 am
I recently installed a home-made hydrogen generator on my 2007 Versa with CVT. The idea is that the HHO gas is produced and ran into the air intake. You then modify the air intake sensor signal to lean the air/fuel mixture saving you gas. At first, my car reved up and bounced the rpm's up and down. Ex. On the fwy my rpm's will be at 2,000 then rev up to 2,500 rpm's. It does this every 4 seconds or so. After this, I completely unistalled the device used to "enhance" the air flow sensor. The car went back to I thought normall operation, then it just lost power and got P0746 error.I cleared the SES error and just took the car out for a test drive. The only issue(that I could duplicate) is after the engine is fully warm my RPM's start to jump around when the engine is placed on a slight load. (i.e I slowly start to accelerate at about 50 mph the engine goes from 2,000 to 2,500) - It hasn't been enough to cause the SES light to come on, but there is a problem for sure. Could I have caused a malfunction in the air flow sensor? I would like to try the dealer as a last resort.
Thanks
