logicpaysoff »
https://forums.nicoclub.com/logicpaysoff-u75470.html
Sun Sep 09, 2007 9:27 am
"You said you've driven 4 V's, and I know almost certainly that 4 different V's would not ALL have ABS"
Actually I drove mine (which has ABS)...and another at the dealership where I bought mine...that one also had ABS.
The one I drove at another dealership had ABS as well. That is three.
The Service Manager drove at least one more Versa from the lot...if not more. I did not ask him if they also had ABS as I assumed he would know to compare apples to apples. I will make a point to ask him if they did indeed have ABS.
That said, as they changed the tires, rotors and calipers, I think if the initial problem was with a hanging caliper, they would have noticed it...even if they did not, chances are that would not be duplicated a second time....but I suppose anything is possible.
Last but not least, on another forum, a response stated that some of the transport truck drivers were securing the cars to the truck by wrapping the chain around the rear suspension beam...causing it to dent...and have been subsequently told not to do so. Apparently, this can cause the car to pull...either to the left or right....which fits in that mine pulls left...and the other pulled right.
Although the work order states that the local dealership performed a pre-delivery inspection albeit post delivery, they did not check off that they looked at the suspension on the multi-point vehicle inspection sheet...so I apparently need to pursue this possibility as well.
