I am in a bind and out of ideas. Can you guys help me please? I have an 07 Nissan Versa with less than 50000 on it. (Mileage irrelevant I suppose)
Problem: None of the power windows will work, nor will the driver side power mirror, nor will the driver side lock button work. But if you use the passenger lock button it works, so will the keyless entry. But none of the passenger windows will roll down period, doesn't matter which door button you try.
Initially I thought fuses like every normal human being. All of them are perfect. Checked them with a tester even.
Then I thought it might be the Main Window Control Switch ( but that doesn't explain the mirror) so I still switched it out. Still nothing. I've been looking for a loose ground or bad wire. Can't find it period. I think some water may've gotten in the door from rain last year, that's when things started going bad. The windows gradually stopped working (so I was told by the girl). DOES ANYONE HAVE ANY IDEAS? Help me lol
