Versa Picture Thread!
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Not the best picture (at all), but I snagged this from Nissan's website:
c5neb
Car: 2007 Fresh Powder Versa SL
cireecnop1 wrote:If anyone wants to know....I used the Maxima badge set from the 2007 3.5 SL. it was $28.00 with tax.thanks guys i appreciate the comments, i wasnt too sure about it a first.
You have started a trend. I plan to do the same. Great idea!!
vidrine
Car: Nissan Versa SL
My new SL with Tinted Windows and 18inch alloys
Modified by vidrine at 12:25 PM 9/24/2006
Modified by vidrine at 12:28 PM 9/24/2006
vidrine
And with Navi
Modified by vidrine at 12:26 PM 9/24/2006
Fen911
Car: 2006 Honda Pilot EX-L/NAV
Your ride looks sick!!!! How does it ride with 18's? What tires are they sitting on ( 205/40) If so how does it ride? I'm thinking of putting 18's also but I'm worried about the ride. I was thinking 17's so that i can put 215/45. It gives me a little bit more tire.
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
Nice Nav system... is that the super uber system with the 30GB hard drive as well?
vidrine
I have 225/40 and the ride is fine the only diff is when you hit a nice bump its a little harsh but not bad. What you would expect with less rubber but freeway ride is the same as stock.The navi is Pioneer AVIC-D2 It has a DVD and CD drive. I installed It myself very tricky install.
LF65
Car: 2007 Versa Blue Onyx 1.8SL Power Pkg. Sony GTX300 stereo, Visoink 300 watt amp and 12 inch sub
How in the hell did you remove the stock radio. I have a nice Sony stereo that I would like to install but can't find a wiring harness for it. Any suggestions??
P.S your ride looks nice!
Thanks!!
vidrine
To remove the radio you must remove the top center of the console, the piece with the two small vents. To remove you need to push the front up about 1/4 of an inch and then grab behind the vents and pull toward you this piece is tricky but once you have removed you will see how easy it is. The first time you remove it, it will seem like you are going to brake it. It take a lot of pressure when you push up to separate. Once you have this piece off you will see 2 Philips head screws on the top of the radio cover remove them and pull the cover off. You can unplug the hazard light switch but DO NOT UNPLUG THE PASSENGER AIR BAG INDICATOR. You can simply pop the light out of the console it has a clip on top and bottom. Them you will see the four Philips head screws holding in the radio. You will only use one of the three harness plug used on you factory radio. The larges one on the drivers side is the one. You will need a multi meter and you should be able to see the speaker wires they should be twisted in pairs. Mine was. The antenna is the gray plug and will need to be cut and spliced into an adapter that you will need to buy. At this time I was unable to find a Wire harness that would adapt I tried a few manufacturers and they are all in the development stage so you will have to splice into the harness. I also was able to use my steering controls using the module from PAC audio. Hope this helps.
kmil123
Car: Jaguar X-Type
What COLOR is your Versa? It looks to me like it could be the Blue Onyx
kmil123
Car: Jaguar X-Type
The "SL" looks GREAT!!! Does it come with the car? Is it from the "Sentra" and if so......how much, IF ANYTHING, did you have to pay? Please email me at: [email protected]
Thanks!
kmil123
Car: Jaguar X-Type
This is exactly the color and specifications I want........EXCEPT I want mine to have ABS [email protected]
GizmoDVD
Car: 2007 Nissan Versa SL
I want that Navi system...whats the exact model # for it?
c5neb
GizmoDVD wrote:I want that Navi system...whats the exact model # for it?
Vidrine says it is the Pioneer AVIC-D2. I saw it on the Crutchfields site. They have three units that fit the dash without modification. They say that you have to splice the wires.....no connector yet. I think I am going to check these out today at one of the big stores. Thanks Vidrine for getting the wheels turning. I think this is going to be one of those "Honey, I have to get one" moments.
c5neb
vidrine wrote:To remove the radio you must remove the top center of the console, the piece with the two small vents. To remove you need to push the front up about 1/4 of an inch and then grab behind the vents and pull toward you this piece is tricky but once you have removed you will see how easy it is. The first time you remove it, it will seem like you are going to brake it. It take a lot of pressure when you push up to separate. Once you have this piece off you will see 2 Philips head screws on the top of the radio cover remove them and pull the cover off. You can unplug the hazard light switch but DO NOT UNPLUG THE PASSENGER AIR BAG INDICATOR. You can simply pop the light out of the console it has a clip on top and bottom. Them you will see the four Philips head screws holding in the radio. You will only use one of the three harness plug used on you factory radio. The larges one on the drivers side is the one. You will need a multi meter and you should be able to see the speaker wires they should be twisted in pairs. Mine was. The antenna is the gray plug and will need to be cut and spliced into an adapter that you will need to buy. At this time I was unable to find a Wire harness that would adapt I tried a few manufacturers and they are all in the development stage so you will have to splice into the harness. I also was able to use my steering controls using the module from PAC audio. Hope this helps.
I would like to use my wheeling controls as well. Can you tell us more about the PAC audio module, where to get it and how you spliced it? Any pictures of the installation?
ekapus
The wife's new wheels. She's had it one week today, and has already racked up about 1000 miles.
kmil123
Car: Jaguar X-Type
Is this Blue Onyx and if so what color is your interior? IF this is Blue Onyx it sure looks close to "Black".
gtr_rider
versa dan wrote:
mmm pretty
http://www.nissan-dakar.com/EN....html
wow already?
gtr_rider
red98s14 wrote:Here's my SL
I think with a nice set of lowering springs that car will look amazing, is it 6spd?
Ever Victorious
'73 AMC Hornet
kmil123 wrote:Is this Blue Onyx and if so what color is your interior? IF this is Blue Onyx it sure looks close to "Black".
As I said, in the lighting I've been shooting it in, it looks black. The car is a really beautiful deep blue. It only photographs well in bright, direct sunlight, which I haven't had the pleasure of so far.
I have a charcoal interior, which also looks great... there's a little blue woven into the cloth, so it ties in really nicely with the exterior color.
red98s14
gtr_rider wrote:I think with a nice set of lowering springs that car will look amazing, is it 6spd?
It's a CVT. She Who Must Be Obeyed doesn't drive stick so it made sense to buy something she can drive. She's already restricted from driving either of my 240's. This is a commuter/daily driver, so there are times when I'm happy with the auto anyway.
I agree about the wheel gap, but I won't be lowering it.
vidrine
I replyed in the Radio Removal thread the PAC module is from Crutchfield.
w1ngzer0
Car: Pfft. i don't own a box
versa dan wrote:
mmm pretty
wow those wheels are small
Vice Versa
GOT
vidrine wrote:My new SL with Tinted Windows and 18inch alloys
Got brakes?
FlightNurse
what model is the SL badge from ? Part #
Thanks
Tony
proxim2020
FlightNurse wrote:what model is the SL badge from ? Part #
Thanks
Tony
Cireecnop1 has all the information here about what to buy.
zerothread/200705
getfdaz1
Car: Versa
Hey everyone new here! but not to nissan forums, owned a couple like max, sentra xe, sentra se-r 93 classic, now 07 versa here the baby! Im interested in that nav, nice job,,
Julz
Car: 07 Nissan Versa
Nothing crazy yet, not enough time to play....
Ever Victorious
'73 AMC Hornet
What gauges are you putting in that pod underneath your mirror control?
By the way - congrads on being the first to post a Red Alert Versa.
kricketkc
If anyone has Pics of the SL in Super Black with Beige interior, can you post pics showing the interior? I suppose if I have to wait this long for it I might as well be sure that is what I want.... Thanks.
